So these are the parts i might use...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153 $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153136 $ 90
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115077 $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220619 $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625 $135
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006 $82
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148681 $160
http://www.newegg.com/Product/Product.aspx?Item=N82E16836113024 $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109191 $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276 $18
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156321 $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124342 $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16815106505 $15
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986 $100
My budget is about $1200 and I plan to use the computer mostly for gaming. I want a lot of RAM. I need it to be able to use a WIFI connection. Are these parts ok? if you change one would you make a suggestion please make sure that it's compatible and if any of these parts arn't compatible please let me know.
