Hey this is my first post here, I joined just now so I could ask this question.
I like to play games a fair bit on my computer. Not overly performance/graphics-intensive ones, mainly Team Fortress 2 and Portal 2. Anyway, all the games I have been playing have been playing have been crashing after playing for a while (usually after 15-30 minutes). No error message or anything, the game process just abruptly ends and I'm left staring at the desktop.
I think the cause of the crashing is some sort of safety feature in the graphics card where it will "shutdown" or something when it gets to a certain temperature to prevent overheating. I have CPUID Hardware Monitor and whenever the game shuts down it's only at around 50ºC, with the "Max" value at 61ºC. I've been told that the card will perform comfortably at 80ºC or even 90ºC so I'm not convinced that it really is overheating.
My specs are:
OS: Windows 7 32-bit
Motherboard: ASUS M4A88TD-M
PSU: Thermaltake Litepower 700W
CPU: AMD Phenom II X6 1090T
RAM: 2 x Kingston 4GB 1333MHz DDR3
Graphics: Sapphire Radeon HD6870 1GB
Also, my entire system will crash to a blue screen every once in a while, around once a week. I'm not sure if that's related. Also, there's a little red light on the motherboard which says "MemOK" which turns on for a few seconds when I turn on the computer. The manual says it means that the RAM isn't installed correctly but I have taken both sticks out and tested them separately in each slot and the light still comes on. I have tested them in every slot using the MemOK button and every time it tells me no errors, but the light still comes on.
Any help for any of these problems would be much appreciated.
My specs are:
