SPCR Power Consumption article
Great article from SPCR discussing power usage in three modern PC configurations:
http://www.silentpcreview.com/article1245-page1.html
I5 2500K at stock speeds and an HD 6870 running Prime95 and Furmark for max power draw....only 271W power draw
...Discuss...
2 answers Last reply
More about spcr power consumption article
    ...Discuss...
    AC
    237w after the conversion, running Prime and Furmark
    A 400 watt psu would be sufficient for normal use with those specs ( don't think you're going to find one with dual pcie connectors though )
  2. Excellent article. It supports my firm belief that it is not necessary to anticipate using as much power as a hair dryer just to play games. With the latest AMD GPUs needing a lot less power, and Kepler rumored to be similar, other data seems to be converging on that conclusion as well.
Power Supplies Power Consumption Power Intel i5 Components
