Have to hit pc to make it work after opening and moving parts around
On my dell Inspirion 530 sometimes when i open it and move parts around and then stand it back up it turns on then turns off then i have to hit it on the side while it is running then it will work, this could be a power supply problem or it could be static shock because it is on a carpet and i did see some static a while ago inside it.
this happened a month ago and no longer happens usually only happens when i remove the cpu and put it back in.
2 answers Last reply
More about have make work opening moving parts around
  1. Have you made sure all connections are tight?
    Casey
  2. Yes, except the graphic card is not seated properly but i cannot fix that because i had to remove some parts of the case to put the graphic card in.
Chipsets Power Supplies Dell Motherboards
