Hey sorry for waiting forever to choose a best answer! Putting together this computer was fantastically fun... all went really smooth! The case is big enough to fit everything and have room for expansion which is great. I wish I had more time to put into using it but now that the school semester has started I haven't had much of a chance to really test this machine to the fullest. I have had no problems with it so far, and it has performed very well. Well worth the investment... Thanks again Kajabla for all of your input, you obviously win BA for this thread.
*With a lot of help from Kajabla I finally decided on a build. Everything below is what I ordered. And now we play the waiting game...
SUBTOTAL FOR ALL PARTS: $787.92
Hello everyone,
I've never built my own computer before, so I wanted to make sure that the system would work before I bought any parts.
First of all, I would be using this computer for a variety of things, but the main use for this computer would be gaming. Since gaming computers require decent processor/video card, it basically encapsulates anything else I'd really need to do. I may also be running multiple virtual machines. Some people say that having six cores is overkill, but even though more and more games are utilizing multiple cores, would it still be a good idea to reduce to a quad-core? I'm trying to make a lasting build.
I'm not really trying to skimp on any parts, but anything that seems like it would be underutilized please let me know. I'm trying to keep the costs as low as possible but still allow me to play games that I enjoy on high settings, preferably ultra but really not necessary. (I.E Skyrim would be awesome)
Here is my build below, I'm pretty sure all parts are compatible but I could be wrong it is my first build!
$220 Processor: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
200$ Processor: AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX
$125 Motherboard: MSI P67A-G45 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$135 Motherboard: GIGABYTE GA-990XA-UD3 AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard
$35 CPU Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 1366/1155 and AMD FM1/AM3+
$30 CPU Cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve
(Plan to OC) 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
$230 Graphics Card: MSI N560GTX-TI Twin Frozr II/OC GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
$280 ($250 w/ rebate) Graphics Card: XFX HD-695X-CDFC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
$30 Memory: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Desktop Memory Model F3-12800CL9D-8GBXL
Hard Drive: Waiting til prices drop, going to use a temp.
$19 Optical Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW
16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
$70 Power Supply: SILVERSTONE Strider Essential series ST60F-ES 600W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
$90 Power Supply: OCZ ZS Series 650W 80PLUS Bronze High Performance Power Supply compatible with Intel
Sandy Bridge Core i3 i5 i7 and AMD Phenom
$50 Computer Case: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
TOTAL: ~$800 I want to keep this under $900 so any weak points anyone spots I still have room to move.
They are all on Newegg so if links don't work google the description and it should pop up. I'm not sure if the power supply would be overkill, or if I can get by with a slightly lesser processor.
My biggest concerns are bottlenecks so if you think I have one let me know!
Also, does anyone know if the components will fit in this case? It seems big enough but I have no way to be sure. Any suggestions with that will be greatly appreciated.
For this build would I need a sound card? The motherboard says it has an on board audio chip set, but I'm not sure if that means I can skip the sound card. I've been told on board sound is plenty.
Any and ALL help is appreciated, and remember, it's my first time, so be gentle!
