I want good 750 Watt Power Supply
Hi
I want 750 Watt Power Supply that has Good Cables & ATI Crossfire Ready
half modular Or full modular Cables
I want to use it with 600T Case
thanks..
6 answers Last reply
More about good watt power supply
  1. ^+1 on the NZXT PSU as I have that very same one and so far has been giving me no problems and looks really good quality-wise. It is half modular but you most likely will need the cables they have fixed in anyways so it won't be a big deal to have it half-modular. Anyways, the cables are black too so it will look nice and yes it is very rock solid as it has a 100% Japanese capacitor and is Seasonic built.
    The link provided above however is for the 650W model.
    Here is the 750W one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817116015
    If you want, there is also a HALE90 series NZXT PSU that is even higher rated in quality and energy usage. It will cost more but I think it is worth it. Take a look:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817116011
  2. Corsair TX750 v2. I've had two of these and they're great. Quiet and reliable and the price can't be beat at $105 right now.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021&Tpk=corsair%20750%20tx
  3. I have been using this one for over a year in my rig, (check signature) and it has been perfect. Its basically the same as the one in the post above, but with a "gold" rating.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139016
  4. Also XFX 750, also Seasonic built.
Power Supplies Crossfire Cable Components Product
