Motherboard is not powering up...Need help.
one_love
78
This is old motherboard with Intel P4 (pin & not pinless) cpu with DDR1 RAM and IDE HDD. I removed all the computer components except powersupply and cpu and try to run it out of cabinet. The powersupply I have is old so brought another powersupply from working pc. I short the green the black (ground) wires to check the powersupply before connecting to motherboard to see if its working before and after connecting to the motherboard. I measured +5v on the power switch header which is available. I short the power switch header with a screwdriver. But the motherboard is not powering up the powersupply and the cpu fans does not rotate. I have clean the motherboard with brush and IP and checked for burnt components or leaky components. I had measured the voltages but I will not get any other voltage except +5v which is standby. Only when the computer starts then only other voltages will be generated. So I doubt the problem is on motherboard restart circuit. Any body have flow chart for dead motherboard or any other pdf documents or give me your own experience if you know the solution...I would be happy to say thankyou. I have multimeter , minisoldering iron hot air soldering station and other tools. Some basic knowledge I have about electronics about components testings like resistors, Mosfet, transistors...
mohamedmoussa
103
hey
On my experience
if the power supply fan's turn on that's mean there are a problem with ur board
if the power supply does not work that's mean u have to check the cable of ON\OFF bottom (small power cable)
one_love
78
I check the motherboard outside the cabinet...the cable was removed...than I short the power switch header on the motherboard with a metal screwdriver...but the motherboard is not powering up...this seems the problem is on the motherboard...and not power switch. I check the power switch with multimeter its fine.
one_love
78
I removed all the connection from the motherboard...except powersupply connectors and cpu fan connector...even check removing cpu fan connector...there is nothing attached on the motherboard no PCI cards...graphic card.
