Hi all
My problem is the whole network (router / switches) is located in one end of the office building and the printer is located in the other end. Its a big multi functional printer with copy, scan etc. At the momemt we have a loooong network cable running on the floor from the one end to the printer.
Unfortunately we dont have an easy way to install cables above the rooms and that way connect the printer via cable to the other end of the building so I need some sort of wireless solution.
The range is approx 20 meters.
I was thinking of installing a wireless router in the printer room and then some wireless adaptors in the pc's (they dont have wireless cards at the moment). But can the pc's have trouble-free connection to both lan and w-lan at the same time ?
Any help would be greatly appreciated
/Faxekondi
/Faxekondi
