Hello everyone,
I am going to be building my first rig the week following Christmas. So far I'm looking at running:
i5 2500k
EVGA GTX 560 Ti
8gb Ripjaws RAM
Asrock Extreme3 Gen3
Probably a 550-600w psu
500g HDD
128 SSD
What I'm most concerned with is that the case I am looking into does not seem to have the ventilation necessary to keep it cool. It has one 22cm and a 9cm fan.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108229
I will also be using a 212+ for the i5 cooling.
When I looked at the picture for the inside, it seemed a fan could be put in the front, back, and the 22 on the side.
Any thoughts you guys may have would be appreciated. As this is my first build and I'm on a limited budget, I'd hate to see something go wrong due to heat.
Thank you in advance.
i5 2500k
EVGA GTX 560 Ti
8gb Ripjaws RAM
500g HDD
128 SSD
