8-pin internal power supply cable
  • Matrox
  • Hardware
  • Power Supplies
  • Video Capture
  • Cable
  • Graphics
  • Product
October 16, 2011 3:17:56 PM
Hello,
I bought from ebay a video capture card Matrox RTX2. However I get the messege, "The setup cannot continue because your Mastrox RTX2 hardware cannot be detected, please make sure that you have correctly installed your RTX2 hardware before running RTX2.utils setup again." The installation manual shows an 8-pin INTERNAL POWER SUPPLY CABLE which i don't have. Where do i get this kind of connector and do I need a separate power supply unit? Thanks
More about : pin internal power supply cable
October 17, 2011 2:10:57 PM
Although the manual says 8-pin internal supply, I see 7-pin in two rows? Does this mean a 14-pin? Is there a 7-pin?
m
l
