Solved
Does gigabyte ga-78lmt-usb3 motherboard work with 1333Mhz ram without OC\'ing?
Does gigabyte ga-78lmt-usb3 motherboard work with 1333Mhz ram without OC'ing?
Official website says that the mobo supports Memory Frequencies 1066 MHz, 1333(O.C) MHz...i have (2x2)4gig 1333Mhz trancend ram...can i use it in this motherboard without any issues?
2 answers Last reply Best Answer
More about does gigabyte 78lmt usb3 motherboard work 1333mhz
  1. Best answer
    Your RAM will work fine. I just assembled a build with a similar Gigabyte board: http://www.gigabyte.com/products/product-page.aspx?pid=4125#sp
    I used 1333MHZ sticks and didn't even have to O/C the memory. CPU-Z showed them running at 667MHZ (x 2) without doing a thing. Even if your board only runs them at 1066MHZ, you can bump the speed up in BIOS with no problem. Or leave it as is.
    Thanks clutchc....thank you so much for your valuable reply :)
Motherboards RAM Gigabyte USB3
