First build advice
toro0508
8
This is my first build and its primarily for gaming and a some stuff on blender. any advice and/or ideas are appreciated. if i can shave off a couple bucks im down but i dont want to sacrifice decent parts for junk. i also plan on future upgrades.
OCing - yes
cpu - phenom 2 970 be
mobo - GIGABYTE GA-990XA-UD3 AM3+ AMD 990X SATA 6Gb/s USB
ram - G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
hdd - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
gpu - MSI R6850 Cyclone PE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
psu - SILVERSTONE Strider Essential series ST60F-ES 600W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
case - AZZA Solano 1000 Black/Black Japanese SECC Steel/Metal mesh in front ATX Full Tower Computer Case
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
Arzhur
174
4
18,695
The case seems pretty expensive. I have an Antec 300 which is less than half the price. It only has two fans installed but I am gaming with a 6950 and 2500k (not overclocked yet) and the temperature does not seem to go over 50 degrees celcius. The Antec 300 may look a plain but it should do the job your build. It also has space for 3 more fans if you want more cooling.
Also seeing how much you you are spending on the mobo and case have you considered getting an i5 2500k instead of the 970 BE?
toro0508
8
I was trying to stick with amd but if I can save money on the mobo and case I might go with the i5. Is the difference between the i5 and 970 gonna be noticeable enough to make a difference? As far as gaming goes that is.
toro0508
8
Thank you and thank you.
toro0508
8
I was trying to keep it below 900 but after seeing this I might not need to.
