Solved
What card will I need?
Im looking to run three 23' monitors at 1080p and handle any game at the highest settings. What kind of cards or card will I be needing. I prefer nvidea evga cards. Money in this case is no object. Nor is space.
Thanks
4 answers Last reply Best Answer
More about what card need
  1. this is probably what youre looking for:
    http://www.eio.com/p-35631-evga-03g-p3-1584-ar-geforce-gtx-580-fermi-3072mb-384-bit-gddr5-pci-express-20-x16-hdcp-ready-sli-support-video-card.aspx
    if budget and space is not an issue for you then that card should be just perfect for you.
    make sure to get a PSU powerful enough to run the system. even bigger if you ever decide on SLI-ing it
  2. Well if money is no object then get two of these;
    EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi) 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655
    If you can catch them at Newegg or someplace else in stock get two of these;
    EVGA 03G-P3-1588-AR GeForce GTX 580 (Fermi) Classified 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130732
  3. Best answer
    $80 cheaper at Newegg and for 3 monitors you need two.
  4. Best answer selected by Hornsan1.
Graphics Cards Games Monitors Graphics Product
