G
Guest
Guest
Hello,
I am looking into purchasing a new, state of the art, 19 inch monitor to replace my older 17 inch. I dont feel that a 21 inch is worth nearly double the cost, not to mention the massive size.
I use my pc a LOT for games, internet surfing and some graphics work and word processing, so a top quality monitor is very important. I would appreciate any advice or recommendations on what you feel is the absolute highest quality 19inch crt monitor out there, price is not an issue. I am currently evaluating at the following models:
Sony CPD-G400
Samsung 900NF
Viewsonic PF795
NEC FP950
Mitsubishi Diamond Pro 900u
of these, what would you recommend? Is there anything else that I should be considering? Thanks, in advance for any assistance.
Sony CPD-G400
Samsung 900NF
Viewsonic PF795
NEC FP950
