Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > [Solved] My monitor blinks with mixed and Checkered colors and system hangs
Forum Systems : Homebuilt [Solved] My monitor blinks with mixed and Checkered colors and system hangs
Best answer from recon-uk.
Hello,
my monitor blinks with mixed and Checkered (plaid) colors and system hangs for a few seconds then after a few seconds it happens again
what's the problem?
my system specifications is:
M.B: Asus P8P67
CPU: Corei7 2600k
V.G.A: xfx 5970 black edition 2g
power: thermaltake 600w
ram: 4g+4g 1600 apacer gold
Reply to amin_ld
mouse pointer will work and right click options are also available after blink
but launcher is absent too
Reply to amin_ld
How old is your 5970?
Do you have any overclocks on any of the parts?
Message edited by recon-uk on 12-14-2011 at 11:34:48 AM
------------------------------ http://i46.tinypic.com/2l963uq.png
2500k|480 2-way SLi|EVGA Z68 FTW. AMD rig in user system configuration.
Notebook: Acer Aspire 5935G|Intel C2D T6600|3GB DDR3|Radeon 4570M
Reply to recon-uk
thanks for the reply my vga is for 3 years ago and yes i have overclocked bothe cpu and vga but i'm runing the system as default optimize but there is still the problrm
Reply to amin_ld
The gpu may be on it's last legs from the sound of your issue or that psu is giving up.
Do you have a spare psu laying around of decent quality and at least 600watts to test?
Message edited by recon-uk on 12-14-2011 at 11:40:16 AM
Reply to recon-uk
How did you overclock your cpu?
By multi or the B-clk?
Reply to recon-uk
i was using a 1500w power before and i'm using the 600w now for the first days there was no problem and i overclocked the cpu by bios and it reached to 4993 mhz but now that it's set to the 3.4 ghz i'm still having the problem
Reply to amin_ld
and i was ocerclocked the gpu too and now it's set to default and i was using the overvolt tool too
Reply to amin_ld
You could have overheated you gpu or it may just be dying...
Reply to recon-uk
i can test a more powerfull power but i was using the 600w and i gived 200w to cpu by bios in the time iwas overclocking it and that was working good but now cpu spends just 120 w power
Reply to amin_ld
Hmmm seems like the 600w psu is not up to the heavy task then pal.
Reply to recon-uk
when i don't use the overvolt tool in amd catalyst center it won't show my gpu heat
Reply to amin_ld
do you recomend to use a better power?
and is there any good software to test hardwares?
Reply to amin_ld
Best answer
ADA64 for psu testing, check 12volt readings.
Furmark for gpu testing for 10mins.
Prime 95 for cpu testing for 1 hour.
Reply to recon-uk
thanks for your answers and i must say i have played run for 1 hour in this circumestances with no problem
Reply to amin_ld
Playing is different to the software i have provided for you.
These will stress the componants to hell and back.
Reply to recon-uk
thanks and can you give me the link for ADA i can't find it
Reply to amin_ld
Reply to recon-uk
thanks a lot i'll use this softwares to test hardwares but how i can be sure the problem is from the hardware (blue screen?
Reply to amin_ld
where in the aida i can test the power?
Reply to amin_ld
is there possible a virus can do this?
Reply to amin_ld
Give us the voltage readings that Aida says, also do what recon says and run those programs, keep an eye on temps.
Reply to mouse24
There are 1545 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 5 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
