Hello, this is my first computer build(going for a gaming rig). I would really appreciate it if you guys would go over the parts I have picked and let me know if I should get that specific part or something else. I'm going for a rig for ~$1000 a little less or more won't really matter. Well here are my parts;
1. Case: NZXT phantom 410
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085
2. MOBO: ASRock Z68 EXTREME4 GEN3 (I don't know if this is a great choice or not, I just don't want a motherboard that is going to fail on me)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157264
3. GPU: EVGA gtx 570 (I will be playing a lot of games so I need a good graphics card)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
4. PSU: OCZ ZT Series 750W Fully-Modular 80PLUS Bronze ( I really like that this is fully modular, buy will it be a good PSU?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341052
5. CPU: intel I5 2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
6. RAM: G.SKILL Sniper Low Voltage Series 8GB 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
7. HDD: Western Digital Caviar Blue 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
8. Heat-sink: COOLER MASTER hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
9. DVD drive: ASUS 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
10. OS: windows 7 home premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
If you guys have any suggestions or parts that are better than what I have I would appreciate the suggestions. I will probably dual SLI somewhere down the road. Also I will be ordering my parts in about a week and a half, so all help is appreciated.
