Fan speed control on mobo
hey guys i just installed my new i5 3570k Asrock z77 pro4-m and when i turned it on everything was literally on full on the fans were extrmely loud so i turned them down to automatic n manual to lvl 5 fan speed can anyone tell me the best fan speeds to keep it cool and normal fan speeds for CPU and fans ty
my build is
i5-3570k Cpu (stock cooler)
Asrock z77 pro4-M
8GB vengeance ram
gtx 460 1GB SSC
600w corsair psu
Monitor: 1920x1200
I play games mostly no bussineswork or anything like that
here is the current settings of my fans in bios
http://imageshack.us/photo/my-images/5/imag0132q.jpg/
and here is my computer from inside just incase you need the how many fans i got
http://imageshack.us/photo/my-images/803/imag0133l.jpg/
More about : fan speed control mobo
Motherboard Master
From what I see, your case is too small and you need the CPU cooler too. Because 1) the i5-3570k runs hot and the stock cooler can't cool down the i5. 2) gtx460 also runs hot too. 3) The PSU blow the hot air into the case too. 4) The real fan maybe only the 80mm. That why the fan try to cool down to run in high speed.
So you only can do 1) open the panel use other fan blow the PC. 2) I recommend buy the case Thermaltake Versa II VO700A1N3N for $25 after MIR and cpu cooler Hyper 212 Plus for $20 after MIR.
http://www.newegg.com/Product/Product.aspx?Item=17C-000...
my computer dosen't run so hot i tested it yesterday runs around 48c~60c cpu and gpu temprature while i play games do i really need to have the cooler can i just get the case?
Related ressources
Motherboard Master
If you don't OC the i5, you get the case first because there is only small space around the cpu. After you have the new case then the whole system has the better air flow and keep the temp down too. Also you need do some cable management too, and I add some pictures in the link. http://images.search.yahoo.com/images/view;_ylt=A0PDoS4PIQRRNSoAiYiJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Dcable%2Bmanagement%2BPC%26_adv_prop%3Dimage%26va%3Dcable%2Bmanagement%2BPC%26fr%3Dyfp-t-701-s%26tab%3Dorganic%26ri%3D74&w=950&h=853&imgurl=123pcmac.fr%2Fcontenu%2Fphotos%2Fmontage%2Fcable_management_pc.jpg&rurl=http%3A%2F%2F123pcmac.fr%2Fmontage_pc_sur_mesure.php&size=258.7+KB&name=Flux+d%26%2339%3Bair+optimal+gr%C3%A2ce+%C3%A0+un+bon+%26%2339%3B%3Cb%3Ecable+management%3C%2Fb%3E%26%2339%3B&p=cable+management+PC&oid=8b17935a429ff166f9262106efe3f403&fr2=&fr=yfp-t-701-s&tt=Flux%2Bd%2526%252339%253Bair%2Boptimal%2Bgr%25C3%25A2ce%2B%25C3%25A0%2Bun%2Bbon%2B%2526%252339%253B%253Cb%253Ecable%2Bmanagement%253C%252Fb%253E%2526%252339%253B&b=61&ni=108&no=74&ts=&tab=organic&sigr=11ctiecv9&sigb=14a26o0o6&sigi=11qcusofv&.crumb=vBukqSqCsRG
thanks for quick replys i just wanna let you guys know i wont OC anything yet maybe my gtx 460 is it okay if i dont get the cool master fan? i can only get the case because i spent like 490$ with psu ram n cpu mobo. Can i get complete list of what i need and like case and what about thermal paste is that only if i get new Fan? and is there good case around 20~40 $ ish
Motherboard Master
1)That case and one fan ($4 after MIR) for inake from front to get better air flow. you can get other one on the top later. I had two of this in my case, it is quiet fan.
2) Get the cpu cooler and thermal paste, either change it for the cpu or the GPU too.
Cin 19 your best man you answered my other noob questions in otherr threads too thanks a lot for that. Can i just get the Case and another Fan only that you linked? will i be okay w/o new cpu fan i just got i5 3570k yesterday i cant rly spend more
and is this case ok?
does it rly come with a fan?
