I'm planning on building a X79 desktop mainly for video and image editing and a little bit of gaming. I have a couple of questions though.
1) I've read a bit about positioning the PSU so the intake is coming from under the case or inside of it. Which of the two would be better off to use? I'd prefer that runs fairly cool and don't have a problem jacking up the case several inches to allow better airflow underneath.
2) For cooling the 3930k, H80 or H100? I do plan on overclocking - probably to ~4.5 GHz. If H100 would be better for this will it fit in my case?
3) Anyone see any problems with this configuration? I'm going to be moving my existing 750 GB hard drive over.
Case: HAF 932 Advanced
CPU: i7-3930K
Motherboard: Sabertooth X79
RAM: CORSAIR Vengeance 16GB (4 x 4GB)
GPU: NVIDIA GeForce GTX 470 (Will eventually be upgrading to 2 cards in SLI after the NVIDIA 600 or 700 series come out)
PSU: COOLER MASTER Silent Pro 850W
Cooler: CORSAIR H100 or CORSAIR H80
Thanks.
CPU: i7-3930K
Thanks.
