AMD 6670 overclocking problem BSOD!
Graphics card Master
Overclocking Expert
Memory Expert
Are you using AMD Overdrive to O.C.?
You've reached the max freq that the stock voltage will support.If you want to get higher clocks you will need to increase the voltage.
Which 6670 are you using?
Related ressources
Overclocking Authority
Memory Master
peiri said:
but on AMD CCC it shows that i can MAX overclock it to GPU clock= 900mhz and memeory =1150
Edit jumped to wrong post!
purple stank said:
Alright make sure you keep an eye on your temps.
No.Their are no BIOS features for GPU's.Your going to have to download MSI Afterburner.
i have the MSI after burner but i cannot increase the core voltage it's locked
Overclocking Expert
Memory Expert
You have to go into the settings within MSI Afterburner to unlock the voltage control.
Also I should let you know that you should be careful while messing around with these settings.If you don't know what your doing you can cause damage to the card.Always watch your temps and don't exceed 80c.And don't increase the voltage a whole lot.Just a very small amount at a time.You should download a stress testing program as well to test if what speed you have it at is stable.
Memory Master
I think you will be happier by just replacing the card with a higher performing card. Overclocks are fine just as long as voltage is kept reasonable. I personally only do overclock as high as I can on std voltage.
Overclocking Expert
Memory Expert
No.
Are you sure you unlocked the voltage control? Make sure you have the latest drivers for your 6670 and the latest version of MSI Afterburner.
Overclocking Expert
Memory Expert
That doesn't make sense.Every card is powered by the motherboard.
It is possible that either your card isn't supported by MSI Afterburner or the voltage is locked from within the BIOS(which is impossible to fix).
Overclocking Expert
Memory Expert
Actually I just found something that might help you.I totally forgot you have to edit some settings in the MSI Afterburner file.
Quote:
Yea make sure you open up Catalyst Control Center, go to ATI Overdrive, and first unlock the card and second disable (uncheck) the ATI Overdrive box. Secondly, in MSI Afterburner, make sure you change the config file where it says "allow unofficialoverclocking =" from 0 to 1. Then you should be good to go.
Tell me if that works for you
meaning my card doesn't have a 6pin connector
Memory Expert
You can change the voltage through the GPU Bios, but I highly recommend NOT doing that.
When OCing a GPU, take it 1 step at a time. Do not increase Core and Memory speeds at the same time. Start with memory and increase it 5mhz at a time (with the Core at stock settings). You already know how high you cannot go, so perhaps start decreasing from there. I would think the Memory is causing the BSODs, but it may be the Core.
Anyway, when you reach the stable limit of Memory speed, then increase the Core speed in the same fashion.
As stated, just because CCC has higher speeds "available" doesn't mean they are reachable. You are only guaranteed that the card can work at stock speeds, anything higher takes patience to figure out.
Anyway, a 6670 is a pretty low end card. You'd do a lot better just getting a 5770/6770 (same card) or 6790 (or anything more expensive than those lol)
Overclocking Expert
Memory Expert
Really, you can adjust the GPU Voltage in the BIOS? What setting is it usually called?
I've seen voltage adjustments for the PCI-E lane or controller but not the card itself.
Memory Expert
I don't mean the mobo BIOS, but the GPU BIOS (aka VBIOS). You need to use Radeon Bios Editor (RBE) which can be downloaded from Techpowerup.com.
However, it's entirely possible that the 6670 VRMs simply can't output a different voltage, but for cards that are able to, you can do it through the VBIOS. Of course this means you then have to reflash the GPU with the new BIOS which is always a bit of a risk.
Again, highly NOT recommended!
Overclocking Expert
Memory Expert
Yah, flashing a GPU is much more risky than flashing a motherboard.Their is no reset switch on GPU BIOS if you mess up so if anything goes wrong you can't use the card anymore.
Ask the community
