Im having problems getting the ati catalyst control ceter
Ghostgirl97
13
answers
Last reply
More about problems catalyst control ceter
full system specs please including OS,
i'm having the same issue with the catalyst control panel. did some digging on other forums and learn't that its a driver issue related to specific builds. could also be a bug in installer.
report back with specs and we maybe can move on from there.
* welcome to the forums - ghostgirl!
** goto filehippo.com and scroll to the bottom of the page; should be able to see catalyst 11.9 for 32bit Windows -
Okay, here are two links (first one 32bit, second 64bit) the "save file" window should automatically pop up if you follow one of the links, do not load the wrong one make sure what windows you have and then download the appropriate one.
http://www2.ati.com/drivers/11-9_vista32_win7_32_dd_ccc_ocl.exe
http://www2.ati.com/drivers/11-9_vista64_win7_64_dd_ccc_ocl.exe
once downloaded install the new driver (no need to uninstall the old driver - it will automatically update the required settings) and then you should be good to go
hope it helps -
dork_police said:Okay, here are two links (first one 32bit, second 64bit) the "save file" window should automatically pop up if you follow one of the links, do not load the wrong one make sure what windows you have and then download the appropriate one.
hope it helps
Yeah.......um my internet has blocked the sited and I can't seem to get to downlaod is thier any other way?
Lutfij said:full system specs please including OS,
OK I have the windows 7 i do tink it is 32g that is all i know is this what you need or somthing eles cause i just need the catalyst control center for sims 3/sims 3 pets........ -
ok i installed the thing, now whatdo i do? and mine is the 32g
Related Resources
Graphics Cards
Sims
Catalyst
ATI
Graphics
Related Resources
- Catalyst control center problems
- ATI Catalyst Control Center Drivers Update?
- Hangs during install/uninstall ATI Catalyst Driver
- Problem with catalyst
- Catalyst Installer Fix 11.2
- My way to unistall Catalyst 8.6-8.8
- Need help installing ATI Catalyst Control Center, Please.
- Catalyst Control Centre wont open
- Catalyst 10.4 not installing
- Catalyst Control Centre doesn't save my changes
- CATALYST 10.2
- Catalyst 10.11 is out,post your results
- Having trouble installing catalyst control center successfully
- Ati catalyst control center stopped working
