Solved
Cooler master storm scout front fan replacement
Last response: in Components
March 21, 2012 5:18:57 AM
I can't find any information anywhere on if a 200MM fan will fit on the front of the storm scout case.
I think the stock fan is 140MM, I would really like to have a 200MM on there. Can anyone help?
a c 110 ) Power supply
March 21, 2012 5:35:19 AM
With some modding yes, but the stock is a 140mm fan.
m
l
Best solution
March 23, 2012 2:33:13 AM
the scout has pre-drilled holes for a 140mm fan or a 120mm fan. And you are correct the stock fan is 140mm.
But as amuffin said, you can drill some holes in it to make a 200mm fit. There is enough room for a 200mm it just dose not have the holes :)
Hope this helps!
March 23, 2012 4:44:59 AM
Best answer selected by -Zombie-.
m
l
