To JCLW,
You will probably only be able to measure the AC line into the power supply with your Fluke clamp meter. Unless it has Hall Effect capabilities (some expensive ones do), a clamp on meter cannot measure DC current, which is what you are looking at inside the PC.
Most common multimeters have an ammeter function capable of DC current measurent, but you have to splice it in series with the wires to get the reading. Plus they usually have a max current rating of 10 to 15 amps(kinda low for this application). Good luck either way... don't electricute yourself.
To Cinder13,
Your Fortron/Source model FSP300-60GT power supply seems to be the same (but relabeled)Sparkle SPI’s FSP300-GT.
(According to this reveiw which can tell you alot about this subject, http://www3.anandtech.com/showdoc.html?i=1128)
(I had read this before, but wasn't able to find it again untill someone else recently posted it, thanks)
Anyways it says that it has a 3.3v leg that is rated at 14 amps. This seems a bit weak if you have a 1.2GHz T-bird with a higher end video card, but it might work.
If you want to wait and see if your current supply will work, setup your system for some tests. If it crashes during 3D Games, but not while running non-graphics intensive applications (like Seti@home), then you probably need a heftier power supply. (as others have recomended, one rated at 20 Amps or better on the 3.3V leg)
Good luck with you system
