Hello,
first time build. My issue is too many choices (ironic). It is a budget build, so here is what I'm looking at.
Both EVGA and both 560 ti cards. same price after rebate. Different models -
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651&Tpk=14-130-651
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610
anyone have experience with either of them? reliability?
I will probably be getting the i5 2500k or 2500. Not sure which, or which MOBO to go with it!
This MOBO with i5 : http://www.newegg.com/Product/Product.aspx?Item=N82E16813130616
or this combo: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.777266
Any suggestions on MOBO's? OC and SLI is a possibility but not a necessity. It would be Mostly experimental, honestly.
Thanks in advance <3
