Solved
Help with a New Graphics Card [No SLI/Crossfire]
  • Graphics Cards
  • Graphics
October 19, 2011 11:39:04 PM
I have :
XFX GS250XYDFC GeForce GTS
750W power supply
Intel Core i5 750 Processor - 2.66GHz Quad Core
Asus P7P55D LE Motherboard - Intel P55, Socket LGA1156, Core i5, 2133MHz, DDR3 [This current one doesn't support SLI/Crossfire :( ]
4 Gb DDR3 Ram
What I want:
I currently produce videos on youtube that showcase me playing a video game. Recording with fraps has become difficult in the better games in the highest resolution. My current card cost me 125. I would like one that allows me to play games on a high resolution without skipping frame rates
What I would like to know:
If upgrading my video card would solve my issue?
What would be the best video car?
What I'm willing to spend [anywhere from the 200-300 dollar range]
I got some help building my computer 1.5 years ago, but I was just starting
and now that I'm producing higher quality I would like to invest in a more powerful graphics card
More about : graphics card sli crossfire
a c 1430 U Graphics card
October 20, 2011 12:09:18 AM
GTX560Ti or HD6950 would be your card a massive upgrade from your current GTS250
m
l
a b U Graphics card
October 20, 2011 12:46:24 AM
Agreed,
6950, 6970
560ti, 570, 580
would be the reccomended cards, depending on ur budget.
m
l
October 20, 2011 12:54:01 AM
And monitor resolution! GTX580 would be a massive overkill @ 1400 x 900!
m
l
October 20, 2011 12:57:08 AM
Thanks for the responses, I know it always seems to be a preference from Radeon to nVidia.
What seems to be your feelings towards them because you seem to be more knowledgable about this. Researching I was thinking HD6950
m
l
Best solution
October 20, 2011 1:01:40 AM
The HD6950 has the performance edge over the GTX560Ti but the GTX does not have to be a lot cheaper to get the performance/price edge. To select between them it is best to look at individual game bench marks and pick the one that score best in your favorite titles. Few games tested here http://www.techpowerup.com/reviews/MSI/GTX_560_Twin_Fro...
October 20, 2011 11:33:48 PM
Monitor resolution is 1980x1080
The HD6950 and the GTX560Ti seem to be roughly the same after comparisons other than the GTX560Ti seems to have some defective cards.
I am probably leaning towards the HD6950, but there are so many versions. Plus the sapphire is only 230 on amazon after rebates. I was willing to go up to 300 but if this card can give me the performance I need I think I should just stick with this.
Any thoughts... Plus should I wait till black friday or with a card like this is it not going to drop. I know TV's and other electronics can drop but they normally just put the crappy electronics on their specials
m
l
October 28, 2011 3:31:45 AM
Best answer selected by pitchingace88.
m
l
