Sicariis Honorable Jan 4, 2013 24 0 10,510 Jan 28, 2013 #1 Will the B75 Pro3-M be fine for a wired connection? Would I need to install anything onto it, like a network card?
Solution geofelt Jan 28, 2013 Sicariis : Will the B75 Pro3-M be fine for a wired connection? Would I need to install anything onto it, like a network card? No need, every modern motherboard I know of has at least one ethernet adapter.
geofelt Titan Oct 9, 2006 54,296 4,145 174,240 Jan 28, 2013 Solution #2 Sicariis : Will the B75 Pro3-M be fine for a wired connection? Would I need to install anything onto it, like a network card? No need, every modern motherboard I know of has at least one ethernet adapter. Upvote 0 Downvote Solution
Sicariis Honorable Jan 4, 2013 24 0 10,510 Jan 28, 2013 #3 Best answer selected by Sicariis. Upvote 0 Downvote
Sicariis Honorable Jan 4, 2013 24 0 10,510 Jan 28, 2013 #4 geofelt : No need, every modern motherboard I know of has at least one ethernet adapter. All I needed to know. Thanks. Upvote 0 Downvote
S smeezekitty Distinguished Sep 11, 2012 6,960 0 18,460 Jan 28, 2013 #5 Specs here: http://www.asrock.com/mb/Intel/B75%20Pro3-M/?cat=Specifications Just look for RJ-45 port Upvote 0 Downvote
