I want a new pc, I play a lot of fps shooters, WoW, HoN, Dota2, Cs:GO, and ect... I asked for help from old teammates that are more pc savy then me and this is what they came up with. I wanted to spend less then 1000 or less but right now its at like 950 not including taxes and I still have to buy windows and a cheap monitor for the gf. ( I have a new monitor already, which I will use and give her this cheaper one that I will buy her and let her use my old pc with.)
Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817341044
Video Card http://www.evga.com/products/moreinfo.asp?pn=01G-P3-1463-KR
Mother Board http://www.newegg.com/Product/Product.aspx?Item=N82E16813131644
Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851
Ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820145325
SSD http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
If you can help me with maybe better bang for the buck stuff for around the same price or cheaper would appreciate it! thanks
