Ram Upgradation Problem
I had one 1gb dynet ddr2 667 mhz ram......it worked fine.,,,,,,,,,,,,
then I decided to add a 2gb kuk ddr2 800 mhz ram.............
i bought a 2gb kuk ddr2 800 mhz ram and now i have a total of 3 gb ram but it is causing problemss..........
blue screen and errors come on startup
sometimes after logon, my apps don't work properly and the same blue screen and error came........
what should i do.......
i think that the new ram is causing problems.....
please help
thnxxx in advance........ :( :(
2 answers Last reply
More about upgradation problem
    please help
    Hi,
    Troubleshoot to find out if the issue is with new memory. Install individually and see if the issue persists. Also, it'd be good if you can check the maximum memory support for your system at this link: http://www.memorystock.com/
    Good luck!
  2. What mobo and CPU? Best bets to start, ensure you have the latest BIOS, the 2GB stick in the slot closest to CPU and the second stick in slot 3 (if 4 slot mobo) or slot 2, prob need to raise DRAM voltage and also MC voltage - guessing here but prob NB voltage on an Intel and CPU/NB on an AMD rig
Memory DDR2 RAM Blue Screen
