Hey, I have just finished the specs for my new computer. I have looked around and think I've got a fairly good build and aren't doing anything stupid but would really appreciate some feedback or advice as id be a fool to spend this much money without people better than me casting an expert eye over it!
Any comments would be very appreciated! thanks a lot!
(to put it into context this computer will be multi-purpose. I want to use it for high end gaming but also development so will need to handle a lot of high end programs and content generators and will need it to be able to virtualize other OS competently. I know that some of the parts are overkill and i could achieve this with slightly lower specs, but i want this to be as future proof as possible, i know better parts will come out but i want it to still be able to run high end games and applications in years to come)
CASE: CoolerMaster Elite 310 Mid Tower Gaming Case with see-thru side panel [-16]
Lights & Illumination: NONE
Extra Case Fan Upgrade: Max. 3 x 120mm Silent Case Cooling Fans in selected case key areas for ultra silent operation [+23] (1,200 RPM AKASA Silent Fans with Sleeve Ball Bearing 17 dBA and LED light to match the Fans already in the case)
Cyberpower Noise Reduction Technology: Cyberpower Sound Absorbing Foam -- reducing audible noise transmitted through solid case panels by up to 75% [+19]
Cyberpower Anti-Vibration Fan Mounts -- reducing the noise transmitted from Fans [+9]
Cyberpower Power Supply Gasket -- reducing the noice transmitted from Power Supply [+5]
CPU: Intel® Core™ i7-3930K 3.20 GHz 12MB Intel Smart Cache LGA2011 ***Overclockable XXX***
FREEBIES: FREE Game - Battlefield 3
Overclocking Service: S&S Overclocking (CPU Safe and Stable overclock: guaranteed min. 10%, max. 20%.)
Cooling Fan: Coolermaster Hyper 412S CPU Fan with 4 x Direct Contact heat-pipes, Extreme performance and Ultra quie ***Overclockable XXX*** [-49]
Coolant for Cyberpower Advance WaterCooling Kits: NONE
MOTHERBOARD: (3-Way SLI Support) Asus P9X79 Pro Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI Bios, BT GO, SSD Caching, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 4 Gen3 PCIe x16 & 2 PCIe x1
Intel Smart Response Technology for Z68: 30 GB Kingston V100 2.5 inch SATA Gaming MLC Solid State Disk [+48]
Internal USB/SATA Expansion Module: NONE
MEMORY: 32GB(8x4GB) PC10666 DDR3/1333mhz Dual Channel Memory [+148] (Kingston Value Brand)
VIDEO CARD: NVIDIA GeForce GTX 560 Ti 2GB 16X PCIe Video Card [-186] (Major Brand Powered by NVIDIA)
FREEBIES: FREE Game - Batman: Arkham City
DONGLES: NONE
VIDEO CARD 2: NVIDIA GeForce GTX 560 Ti 2GB 16X PCIe Video Card [+199] (Major Brand Powered by NVIDIA)
Video Card 3: None, or On-Board Integrated Graphics
Dedicated PhysX Card: NVIDIA GeForce GT 430 1GB 16X PCI Express [+41] (Major Brand Power by NVIDIA)
Power Supply Upgrade: 850 Watts Power Supplies (CoolerMaster 850watt Silent ProModular Gaming Power Supply, SLI / Crossfire ready [+25])
Hard Drive: 2TB SATA-II 3.0Gb/s 32M Cache Hard Drive [+26] (2TB (2TBx2) Raid 1 High Performance with Data Security [+106])
Data Hard Drive: 3TB (3TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [+192] (Single Hard Drive)
Hard Drive Cooler: None
Optical Drive: 24X Double Layer Dual Format DVD±R/±RW + CD-R/RW DRIVE. (BLACK COLOR)
Optical Drive 2: Samsung SH-B123 12X Blu-Ray Player (please select the Blue Ray software in the Software section) [+45]
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
Network: ONBOARD 10/100/1000 GIGABIT LAN PORT -- As standard on all PCs
Wireless 802.11B/G Network Card: PCI-E Wireless 802.11n 300Mbps Network Interface Card [+17]
External Wireless Network Adapter: NONE
Wireless 802.11B/G/N Access Point: NONE
Bluetooth: None
Flash Media Reader/Writer: INTERNAL 52in1 Flash Media Reader/Writer (BLACK COLOR [+5])
Video Camera: None
Cables: None
Power Surge Protection: None
IEEE 1394 Card: NONE
USB Port: Built-in USB 2.0 Ports
USB and External Drive: NONE
Floppy: NONE
Ultra Care Option: CoolerMaster Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation [+9]
Professional Wiring for All WIRING Inside The System Chasis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
Ultra Enhanced Packaging Solution Mid Tower - Protect Your Dream System During Transit [+14]
Operating System: Microsoft® Windows® 7 Home Premium (64-bit Edition)
DONGLES: NONE
Bluetooth: None
Video Camera: None
Cables: None
Floppy: NONE
