Can you wire a wall device into a PSU?
azurehobo
88
I recently moved an original Xbox into an old PC case (from 1998). Right now I have the PC PSU left in the case to run extra fans for more airflow, but I was wondering can I plug wire in the Xbox power cord into a Molex or the Motherboard plug (the PSU is a 20 pin)?.
I'm not trying to skip the Xbox PSU at all, I just want to take it's wall plug (positive and negative prongs) and try to run them through the PC PSU so I only have to plug in one plug into the wall socket. Would this be easy to accomplish?
azurehobo
88
Ok. Thanks everyone, I'll either stick with the two power cords or put a strip inside and run a single wire out.
