Display problem
I turned my studio 1535 on and the dell logo was rolling across the screen from the top to the bottom. As it booted, got worse. Could barely make out the safe mode screen. Got worse. Turned into a bunch of horizontal lines that rarely refreshed and began to fade to white. I re seated lcd cable to motherboard. No luck. I tried external display, came up all black. I cannot remove radeony 3450 card (i don't think) as it appears hot glued in? Is she fried? Or could it be inverter or something simple.
Thx!
More about : display problem
Graphics card Master
Doesn't make sense that you can't move the card , did you move the plastic latch that hlods pci-e cards in the slot? What do you mean by tried external display? Your desciption sounds like either the monitor or the video card is defective, Are you still able to under warrenty call Dell support?
Wait did you try a different monitor- I can't tell from your post. If the problem does lie in your graphics card, then you either will need to get a different one (make sure you have enough wattage for the new one) or worst case scenario a new graphics card and motherboard. It's impossible to know exactly what the problem is without some more troubleshooting on your part but we can deduce a few components that should be running fine.
1. RAM (if this was not the case you would probably get a weird error message)
2. CPU
3. HDD
Another possibility could be the power supply. How old is this computer and is it under warranty? If it's under warranty, just send it back and save yourself the trouble.
Graphics card Expert
The fault is caused by the monitor not syncing with the graphics card, this could be caused by the sync rate being wrong (faulty graphics card) or broken connection from the graphics card to the monitor (cable not plugged in properly or cable broken) or a faulty monitor.
The on-board graphics will be disabled when the graphics card is fitted which is why it was black when you plugged the cable into it. The graphics card is held into place by a little latch at the bottom end of the graphics card and a screw at the top front end. Graphics cards are not glued into place.
Ask the community
