Solved
Cables Required for a first build
What Cables would I need to purchase off of new egg to make this "bare drive" not so bare. Also do you recommend Buying windows 7 oem or windows 7 retail?? Thank you very much for your time and Knowledge.
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
3 answers Last reply Best Answer
More about cables required build
  1. Best answer
    SATA cables. You can get them at Newegg or Amazon. But you may have some SATA cables accompanying your mobo.
    The shorter the cable the less loss of transmission, but also less flexibility for placing the drive.
  2. Best answer selected by Silverssaint.
  3. so i should be fine with what accompanies the mobo?
Cable Components
