My question is simple. Will all of these components work together without an issue? I have some concern about the video card. Does it require any kind of hook up to the motherboard via wire/cable?
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131142
XFX HD-677X-ZNLC Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150540
1 x OCZ GameXStream OCZ600GXSSLI 600W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341001
I already have the mobo and power supply, am just looking for a cheap improvement to the system and this video card seems spot on.
