Will this RAM work with this motherboard?
Hello.
Will this http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 work with an ASRock Z77 Extreme4?
If not, which 8GB (2x4GB) dual-channel RAM do you recommend?
Thank you
1 answer Last reply
More about will work motherboard
  1. It should work fine. That's pretty much the std memory for the board.
Memory RAM Dual Channel ASrock Motherboards Product
