ko888 :
That power supply should be more than capable of powering your system with a single Radeon HD 5770.
Are you using the 6-pin PCI Express supplementary power connector on the +12V3 rail?
You can identify it by looking at the yellow colored wires connected to the 6-pin PCIe connector. It should have yellow with blue stripe wires. This is the one that should be used with the Radeon HD 5770.
If you're using the other 6-pin PCIe connector it is sharing power with the two 4-pin ATX CPU power connectors. If the graphics card draws more power than that rail can provide the CPU will be starved of power and you'll experience the symptoms that you've described.
i acually using this video card for 2 months and i play almost 12 hours a day lol
2 months straight i experience no problem . yes i do have a 6-pin PCIe connector on my Acbel 660 and thats the one im using for 2 months
and this month my computer turns off suddenly and i tried to turn it on again. it will turn off after a second ... and i experienced it for a week
and i just have to cool it down for 1 hour and it will work again. then the other day it turn off suddenly and i sleep. the next morning i tried to
turn it on but there is no display on the scree black screen but my computer is on. and i tried to remove the Vcard hd 5770 and then the computer
starts to boot up again BUT after hours of using it still automatically turns off.. i don't know what should i buy.. but i wish the vcard aren't damaged.
