Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Screen Resolution problem.
Forum Graphics & Displays : Graphics Cards Screen Resolution problem.
Hey everyone.
I have just built a new HTPC, its all working fine.
Specs are:
GIGABYTE Z68XP-UD3 Motherboard
Intel i5 2500K Processor
120GB SSD Hard Drive
LG Blu Ray Drive
Currently no Video Card.
Anyways I was hoping to plug my HDMI cable into my Panasonic Viera LCD TV and run my computer through that. Using the onboard graphics of the motherboard. However it is only outputing at 800x600 screen resolution.
Is there anyway I can change this, or will I have to invest in a Video Card.
Reply to Tbalasso
I assume you've tried to change the resolution through the Windows screen resolution settings.
Do you have the latest VGA driver installed?
http://www.gigabyte.la/products/pr [...] 892#driver
If that doesn't fix it, then check to see if you have the latest BIOS:
http://www.gigabyte.la/products/pr [...] =3892#bios
It's possible it could be your LCD - what is the specific model number?
Reply to jjhuang42
Have you adjusted the screen resolution?
Right click on the desktop, select "Screen Resolution" and use the drop-down menu to select the correct resolution.
Reply to blade061188
Why do u have such a rig for a HTPC ?
------------------------------ True Malaysia
Malaysian Fact
LittleGreg:Core i5-2500,8GB ddr3,MSI P67A-C45,Sapphire HD6950 1GB,3TB Total HDD,Xigmatek NRP-PC602
Lappy: Athlonx2QL62, 4GB ddr2, HD 3200 IGP
Reply to greghome
There are 1429 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 4 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
