2 different cards for SLI - help!
death orb
12
I have a gtx 460 cyclone OC 1gb http://www.guru3d.com/article/msi-geforce-gtx-460-cyclone-oc-1024-review/
They aren't - or don't seem to be available anymore!
So my second card is a tough choice!
If no-one can suggest a UK retailer with a cyclone or any msi 460 in stock, then what should I get?
Was thinking this - http://www.scan.co.uk/products/1gb-evga-gtx-460-superclocked-3800mhz-gddr5-gpu-763mhz-shader-clock-1526mhz-336-cores-2x-dl-dvi-i-mi
It should be fine if I OC both of them with afterburner, right? Any problems with different manufacturers for SLI?
Please don't suggest, 2 x 560's or a 570 - It would cost too much!
And overclockers/scan/etc - said they can't re-stock the 460's! Discontinued....damn!
Aaaagh! Help! :bounce:
