Boot problem with Win 7 ("Missing Operating System" Error
Today morning I powered up my PC and it got through the Motherboard Splash Screen, Seemed to startup properly and then I got this message in blocky white letters on a black background "Missing Operating System"
I cut the power cause it didnt seem to be going anywhere and then powered up again
I got the same problem
cut power and started again this time I entered into BIOS and looked at the HDD to see if there were any problems
It looked ok
then i looked at the boot sequence and changed it from
HDD
CD/DVD
Other
to
HDD
HDD
Other
and booted again
This time it booted into windows perfectly
I would really like to know what this problem might be
Is it a virus ?
or a symptom of HDD failure ?
any help would be much appreciated
Thank You
4 answers Last reply
More about boot problem missing operating system error
  1. Well, u don't cut the power. Try the reset button first.
    What is the mobo?
  2. make sure you didnt leave a cd/dvd in the drive
  3. Sorry ..Thats what I meant ..words failed me :/
    Never had problems before with DVDs in the drive
    Anyways ill do that and see
    thanks
System Error Windows 7
