Solved
PSU atx problem
Last response: in Components
Hello,
I bought a new psu , Zebronics Platinum 500w. But it has 20 pin connector and also 4 pin connector attached together and these two are covered by good covering, but i cannot connect the 4 pin to my motherboard atx power for CPU. Is it good to tear the covering and connect it to mobo to make it reach the CPI or is there any other ways ?
More about : psu atx problem
Power supply Master
Hello james124;
Don't rip apart the 20+4 connector.
Use the separate 4pin ATX 12v connector
Zebronics Power supplies >> Platinum series >> ZEB-500W
http://zebronics.com/productDetails.php?id=98
24 (20+4) Pin Connector x1
-> ATX 12v 4 Pin Connector x1
EPS 12v 8 Pin Connector x1
PCI Express 6 Pin Connector x1
Peripheral 4 Pin Connector x4
SATA 15 Pin Connector x4
Floppy 4 Pin Connector x1
Related ressources
Power supply Master
There should be EPS/ATX adapter cables to change the EPS 8pin PSU cable to ATX 4pin PSU cable.
You definitely don't want to use the 20+4 4pin connector.
Does the EPS 8pin connector look like it's designed to split into a 4pin connector?
If there is room for it to fit - you can use the EPS 8pin cable on the 4pin motherboard aux CPU connector.
Ask the community
