Problems with installing new RAM modules - Asus P7H55/USB3
I had 4gb of DDR3 memory in two 2gb sticks and decided to install 8gb more.
After removing the old sticks and placing the new ones the computer won't start.
It stays hanged up on BIOS splash screen, BIOS options cannot be accessed. Removing the new sticks and placing the old ones causes the computer to boot up properly.
Inserting only one new stick makes the computer go through the BIOS startup, but it projects a blue screen and resets too quickly to read it when Windows starts booting.
Current motherboard: Asus P7H55-USB3
BIOS: American Megatrends; Version 1708; Date: 12/14/2010
New memory sticks: Patriot PV38G160C9K
Old ones: Don't know the exact name
CPU-Z details: Module Size 2048MBytes,
Max Bandwidth PC3-8500F(533MHz)
Manufacturer: Patriot Memory
Part Number 1600LL Series
What could be causing the problems? Any idea how to solve them?
I'll provide additional details if they are necessary.
9 answers Last reply
More about problems installing modules asus p7h55 usb3
  1. From the board specs: 4 x DIMM, Max. 16 GB, DDR3 2200(O.C.)/2000/1866/1600/1333 Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    Supports Intel® Extreme Memory Profile (XMP)
    *Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Please refer to Memory QVL for details.
    *Refer to www.asus.com or this user manual for the Memory QVL (Qualified Vendors Lists).
    So only 4GB per RAM stick.
    Well, the sticks are 4GB each, so this shouldn't be a problem.
  3. It might be a compatibility issue. Check on the Patriot site (using the configurator) the compatible kits for your board.
    I'm not sure if I'm using the configurator tool right. It shows me only two sets of RAM, none of which is even the old one I'm using. I tried contacting Patriot's tech support, waiting for an answer now.
  5. Yes, contacting Patriot is the best option. If returning the RAMs, try Corsair, GSkill or Kingston. Use configurators for finding compatible kits.
    Well, I'll do it. Thanks for your time. I'll update the thread once the issue is resolved, might help someone in the future.
  7. UPDATE
    Nothing I tried could make these RAM sticks work. I had them changed for a different model (Corsair CMZ8GX3M2A1600C9R), and the new ones work fine.
  8. I have the exact same motherboard.I tried to upgrade ram from 2x1gb kingston hyperx to 2x4gb CORSAIR CMZ8GX3M2A1600C9B VENGEANCE 1600mhz but my computer didn't start either . If you have any usefull information after solving your issue I'd aprecciate it if you could share it with me.
  9. Do you have latest BIOS?
Memory BIOS
