Wireless networking
Hello,
How do i find out where to find my wep address security code for my netgear wireless router
3 answers Last reply
More about wireless networking
  1. It's located deep with an Integrated Circuit.
    Push the reset button for 5-10 seconds to reset the router.
    It reverts back to all factory settings, including the default log-in username and password.
    Google the model number to get default login info, setup router wireless security again and this time don't loose the key you entered.
  2. if it is the password that you use to log into the router, the default should be "admin".
    if this does not work, you will need to reset the router to manufacturer default.
Wireless Wireless Router Networking Wireless Networking
