So I decided my I7 920 was due to be replaced. I ordered a 3930k, Asus P9X79, Corsair vengeance 16G quad channel kit, and a Samsung 830 256GB SSD. I am going to reuse my current video card which is an EVGA superclocked 570. I will also repurpose my existing HDD's for programs.
I may like to overclock this system, plus I do some Blu-Ray encoding which really pegs all cores and threads for an extended period of time.
The only thing I have left is cooling and a case. I am currently using a thermaltake Armor MX case and due to budget constraints ( Actually my budget is already choking to death) I would like to reuse if possible.
I am really liking the H100 but am not sure if I can make it fit in my case or not. Does anyone here use that combination? or have any ideas regarding it. I am also cosidering the H80 as it will fit in my case and the Thermaltake Archon.
I also read here that voltage regulator cooling can be affected by using water cooling. Any thoughts on this?
Thanks in advance!
Thanks in advance!
