Sign-in / Sign-up
Motherboard help?
  • Corsair
  • Hewlett Packard
  • Motherboards
  • Memory
Last response: in Memory
February 1, 2013 3:53:48 PM
Hello, i am new to this forum. i am looking for a new mother board that fits in with the parts below
i have recently bought
new corsair 8gb
http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1600C9-1600MH...
as well as i also have an asus radeon 5450
http://www.amazon.co.uk/Asus-Radeon-Silent-Profile-Brac...
i have a pentium(r) dual core cpu E5800 @ 3.20ghz.
i have a standard 350w HP power supply
Seagate 1TB/1000gb hard drive and a dvd/writer.
i am looking for a new motherboard as mine is a standard HP motherboard that is from a HP G5410UK pc. it is a stndard ATX motherboard NOT Micro!!!
thanks brandon
More about : motherboard
a c 260 V Motherboard
a c 99 } Memory
a b α HP
February 1, 2013 9:26:06 PM
According to HP's specs found here http://h20000.www2.hp.com/bizsupport/TechSupport/Docume... your motherboard is micro-ATX form factor. I will highly advise against attempting to use a full ATX board in that chassis.
I might suggest the ASRock G41C-GS but I am unaware of any socket 775 CPU/mobo combo that will run ram natively at 1600MHz - the ram should work but will likely max out at 1333 unless overclocked.
Hope it helps
a b V Motherboard
a b } Memory
February 1, 2013 9:31:33 PM
why would you want a new motherboard in that system?
February 3, 2013 8:39:38 PM
new corsair 8gb
thanks brandon
oh yes so it is i never realised that......lol. and thanks
and i wanted to know what the upgrades would cost as i am trying to better the performance of my pc
a c 99 } Memory
a b α HP
February 3, 2013 9:30:06 PM
What activities are you looking to improve? That may help decide which direction to take for an upgrade
February 3, 2013 9:44:21 PM
overall speed pereformance and to have more ram, as i have just realised that my motherboard only supports upto 4gb if im correct, and as i have 8gb theres 4 useless gb's. i would like it to not be green if possible as i have a white mars cit case that is part see through. i was hoping to have a nicer looking pc rather than the bog standard boring green.
thanks
a c 99 } Memory
a b α HP
February 3, 2013 10:05:45 PM
One more thing to consider here is that a change of motherboard will require a new operating system since your Windows license through HP is for that 'system' with motherboard intact. Virually everything within a computer can be changed out without worrying about a new OS license, the motherboard is the exception. I think the ASRock board should work unless there are specific features you are looking for that are not there. Here is a list of your options as presented by Amazon http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-ali...
a b V Motherboard
a b } Memory
February 3, 2013 10:23:32 PM
swapping a motherboard isnt worth it, getting a new mb/cpu/ram is.
