Best way to transfer programs from old system HDD to new Build HDD?
Hey Tech Authorities,
What is the best way to get all the info from an old build to a new build? Do you have to somehow write down your own list of programs from some files and then re-install everything, or is there an easier way?
How do you guys get everything you want off an old build and then onto a new one?
I do have a 3GB external HDD if that helps.
Thanks,
-TG
1 answer Last reply
More about best transfer programs system build
  1. I just used an external HDD, you can use various backup programs W7 has one or ninite.com for installing the most popular programs
Build New Build Hard Drives Systems
