Hi,
I posted here a couple of months back thinking i would be getting a build then, but decided to hold out as long as i could on my old pc before biting the bullet and getting a new one. Anyway, my gaming laptop died 3 days ago and even my wife wants me to hurry up and get a new PC.
I think most of what I've chosen is pretty good, [strike]but I have concerns about the CASE, room in the Case and size of my RAM interfering w/ the CPU Cooler. [/strike]
I have never built a PC before.
Budget: $1250
Use: Gaming(StarCraft II, Rift, SWTOR), Working (Computer Programmer SQL Server 2005 and 2008. VS 2005,2008,2010)
Preferred Vendors: NewEgg, Amazon, Microcenter (whichever is cheaper)
My Monitor: ASUS 24"" 1080p
Don't Need: Keyboard, Mouse, Monitor
[strike]CASE: Antec 300 Illusion (can i turn off the blue leds if they annoy me?) - Is there a better case for: $69.99 ?[/strike]
New Case:Corsair Carbide Series 400R (Combo Deal with the PowerSupply)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139008
Power Supply: Corsair TX750 (don't think i can go wrong here): $105.99
url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
MotherBoard: ASRock Z68 Extreme3 Gen3 LGA 1155 (will use CrossFire Eventually) : $129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
RAM: Corsair Vengeance 8gb : $41.99 **Changed to low profile to accommodate CPU Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233196
CPU: I5-2500k : 179.99 @ MicroCenter
CPU Cooloer: Hyper 212 EVO :$34.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
GPU: Gigabyte 6950 1gb will Crossfire in 1-2 years when i need a graphics boost: $239.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125385
SSD: Corsair 3 series 180gb (120 doesn't seem like enough and 240+ is just too expensive): $249.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233220
HD: Seagate Barracuda 1tb 6.0gb/s (stupid flood, wish it was WD 1tb Caviar Black): $129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
Samsung CD/DVD Burner: $17.99
SubTotal: $1204.90
Now My Questions.
[strike]So, any better ideas for a Case? [/strike] Going with Corsair Carbide 400r
[strike]Will this RAM/CPU Cooler system play nice?[/strike] Went w/ low profile
[strike]Do I need to buy Thermal Paste?[/strike] Apparently comes with the CPU Fan
I know i'm supposed to do Apps on the SSD and music, videos, documents etc... on the HD, is that just right-clicking "My Documents" and selecting move? Is it that easy? Or am I supposed to do something crazy?
Do I need to change the firmware on anything before I install Windows 7 Professional?
Do I need to change any Windows settings to play nice with my SSD?
Budget: $1250
SubTotal: $1204.90
Now My Questions.
