Computer will not go on after cleaning CPU HELP!!
Hi,
I am only after taking my computer apart to clean my cpu. I applied thermal paste all correctly using the card method. I cleaned old paste with alcohol I got from the computer shop and then used toilet roll to dry. This is my first PC that I built and I am so worried that I have damaged my CPU in someway. Can someone please help me!
Intel i5 2500k
2 answers Last reply
More about computer cleaning help
  1. Hi :)
    Did you bend any cpu pins ?
    Did you accidentally disconnect any leads internally ?
    This is a PC or Laptop ?
    All the best Brett :)
  2. You took your CPU out to clean it? WHY!?
    It can be very likely that you killed it with electricity. If you weren't grounded/neutral when you touched it, your static electricity could have easily fryed the CPU.
CPUs Computers Thermal Compound
