Znoel87 Honorable Mar 25, 2012 43 0 10,530 Mar 27, 2012 #1 Hi I was wondering what I need to buy to cool my i7-3960x paired with an Asus Rampage IV Etreme mobo? Do I need small fan or liquid cooling. Its my first build and I'm lost. Any help will be much appreciated
R rendermonkey1 Honorable Mar 26, 2012 9 0 10,510 Mar 27, 2012 #2 This is what I got for my i7 3960x http://www.newegg.com/Product/Product.aspx?Item=N82E16835233082 The price was right, It's a big one though. Upvote 0 Downvote
amuffin Illustrious Jul 29, 2011 14,977 1 41,960 Mar 27, 2012 #3 Better choice, and cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 Will you overclock? Are you looking at a custom watercooling loop? Upvote 0 Downvote
R rendermonkey1 Honorable Mar 26, 2012 9 0 10,510 Mar 27, 2012 #4 I looked at that one too, but I don't think it's socket 2011 compatible. Do you know if it is or not? Upvote 0 Downvote
amuffin Illustrious Jul 29, 2011 14,977 1 41,960 Mar 27, 2012 #5 The newer version is: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 Upvote 0 Downvote
