Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > System says "No hard disk detected" but boots fine of the SSD
Forum Systems : Homebuilt System says "No hard disk detected" but boots fine of the SSD
My current system has a SSD boot drive as well as a standard hard drive. Whenever I boot the system, it takes a few seconds running through some protocol before it reads "No hard disk is detected," and then proceeds to finish booting. Is it doing this because windows does not consider an SSD a hard disk? Is it not detecting my actual hard drive on bootup? Is there any way to get rid of this so I can increase my boot times?
------------------------------ Intel Core i5-2500K | ASUS P8P67 LE B3 MoBo | 2x4GB G.SKILL Ripjaws 1300Mhz | GTX 460 1GB | Corsair FS60 | Samsung Spinpoint F3 | XFX XXX 650W | ZALMAN CNPS9500 Fan/Heatsink
Reply to JamesAllen
SSDs are more like RAM or thumb drives than they are like regular hard drives.
It is trying to tell you that it can't find your regular hard drive.
Can you use files on it when you are in Windows just fine?
It really depends on your BIOS what you can do to address this issue.
Some BIOSs let you skip certain steps and others not.
Generally speaking, Windows likes to see an attached hard drive, so you may have quite some difficulty trying to get rid of this error.
------------------------------ i5-3570k, Asrock Z77 Pro4, XFX Pro 650w Core, 2x 4GB Crucial CT2KIT51264BA1339, PowerColor 6850 SCS3, Lian Li PC - K59, Seagate Barracuda 500gb hd, ASUS DRW-24B1ST DVDRW
Planning a build, click here: http://tinyurl.com/82pnrn6
Reply to Raiddinn
I'm going to take a different guess; I get a similar message. The motherboard has a Marvell disk controller in addition to the southbridge ports. When I boot without any drives attached to the Marvell controller, and the controller is enabled, I get a similar message. My board is an earlier Asus model.
Look in the BIOS for on-board components and disable the Marvell controller. If that makes the message go away, you can consider leaving it disabled until you need it.
If it can't be disabled in the BIOS and you are really, really curious, disconnect your HDD and connect it to the Marvell-controlled ports. If the message goes away, I was right.
Reply to WyomingKnott
I'd check your boot priorities in your bios and make sure that the ssd is selected as your primary (master) drive. It sounds like it is checking your other drive first and reads that it doesn't have an operating system on it and then checking the next drive and sees that that has windows on it and then boots.
------------------------------ i5 2500k @4.4Ghz | hyper 212+ | GA-P67A-UD4 |2x4GB Gskill Ripjaw | Corsair 850HX |MSI GTX 560ti Twin Frozr II (SLI soon) | 90GB Vertex 2 SSD | 2xWD 500GB HDD | @1920x1080
Reply to crewton
There are 1526 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Review my build ($1,000 Gaming PC)
By Silvune, 10 minutes ago:
Personally I think I would go with the mATX board and save the money. Here is a review...
Best offers
Top experts
