Help with first AMD Build
Last response: in Systems
Hi I'm new to building computers and I'm about to receive some parts from my friend to build a new computer.
Here's the parts:
GPU- HD 5850
CPU- AMD 965
Intel 80gb SSD
G.Skill 4GB Ram
I'm thinking about buying these parts:
Case- CM 690ii advanced
PSU- need help with this, is a 650w psu gonna be ok?
Motherboard- Biostar 990fx ($110)
What else would I need to complete this build? (besides monitor,mouse,keyboard)
More about : amd build
- Some kind of Hard Drive... around 1TB in size to install apps and games on (use the SSD for Windows).
- Some sort of Optical Drive just to install some software/games that are on CDs/DVDs.
The PSU ought to be fine at 650W but you might want to be careful on the brand. I would recommend Corsair, PC Power&Cooling/OCZ or something from Antec that is a little more highend.
Here's the parts:
GPU- HD 5850
CPU- AMD 965
Intel 80gb SSD
G.Skill 4GB Ram
I would get a bigger SSD. An 80 gig SSD really is nothing and will get filled up so fast. If your doing just a boot drive i would do at least a 128 gig SSD. If your going to be using the SSD for more than just a boot drive I would go even bigger or use a standard HDD with an SSD boot drive. The SSD will hold all vital OS information and the standard HDD will hold all other info.
As for the PSU the 650 watt should be fine as long as you get a good quality PSU. I would look at Seasonic or Corsair and get a PSU that is at least 80+ bronze certified, although if you can I would go with 80+ gold certified. If your using this computer for gaming look at mechanical gaming keyboards and a gaming mouse.
Related ressources
Ask the community
