Custom case help!
Hi im going to make a awesome case! so... I don't know if you have ever seen some of the more unique cases such as the pizza box case or the toilet case... this is what I want to do.
So I need help deciding what I want to use so a beer box pizza case etc.. so any one with some ideas would be nice...
also im not sure how I would turn the computer on as in a normal atx sized case it would have the on/rest button attacked to the mother bored so yeah thanks and get back to me soon :)
6 answers Last reply
More about custom case help
  1. To turn it on and off most people remove the front I/O from an old case and then just use that on their custom case.
  2. Put your computer inside one of those beer fridges. and good luck
  3. Quote:
    On/Off just requires you to wire up a momentary switch to the appropriate header on your motherboard.
  4. cut-up beer can's ... and foil-up your old case with it.
  5. http://www.radioshack.com/product/index.jsp?productId=2062496
    pull the wires off an exsisting i/o panel attach to any momentary switch
    I really like this idea! awesome look and cooling ;)
Power Supplies Cases Computers Components
