ASROCK Extreme 6 XMP Issues?
Decided to go with ASrock X79 Extreme 6 and paired it with i7 3930k.....Having issues getting Ram to run over 1600Mhz, tried XMP 1.2 and PC won't boot, tried setting manually 1866 and 2133 still no post. Only runs at 1600, installed sticks in correct slots as per ASrock, A1,B1,C1,D1? Did not bother to flash bios because i have version 2.20 which is latest at ASrock website......Right now sticks are running at a stable 1600Mhz with timings of 8-8-8-24-1T but was informed that my Gskill Model (F3-17000CL11Q-16GBXL) should have no problems being recognized by board and run at rated speed of 2133Mhz. Never had a problem running these on my Gigabyte Z68 using XMP. What could be the issue here?
Intel Core i7-3930K Sandy Bridge-E 3.2GHz LGA 2011 6-Core CPU
ASRock X79 Extreme6 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL11Q-16GBXL
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal (SSD)
MSI N560GTX-Ti Hawk GeForce GTX 560 Ti (Fermi) 1GB 256-bit 1150Mhz (OC)
CORSAIR Enthusiast Series TX850M 850W ATX12V High Performance PSU
Hauppauge WinTV-DCR-2650 Dual Tuner Digital CableCARD Receiver
COOLER MASTER Hyper 212 EVO RR-212 Push/Pull
Corsair Carbide Series 400R Graphite ATX Mid Tower Gaming Case
ASUS 24” HDMI 2ms Monitor
Logitech 7.1 Surround Sound 6 Speaker System
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive
Seagate 160 Gb External Hard Drive
COOLER MASTER R4-L2S-122B-GP 120mm 4 Blue LED x 3 Fans
6 answers Last reply
More about asrock extreme issues
  1. Try to reset bios and set the settings(frequency, timing and voltage) manually again. Have you overclocked the processor by increasing black?
    Wait for a bios update, until then use it at 1600MHz. The speed will be the same as the timings has reduced to 8-8-8-20 when working at 1600MHz
  2. Ram timing can be picky. If your board supports adjustments to RAM LLC (load line calibration) up it a little bit that can help stabilize memory timings
    I have tried setting XMP and manually setting to 1866 and 2133 but it won't boot. Have to then clear bios, it defaults to 1600Mhz with timings of 11-11-11-28-1T at 1.605 V. My board supports both XMP 1.2 and 1.3 and shows profile 1 as being 11-11-11-30-1T if it were actually going to work. I can lower my timings down to 8-8-8-24-1T but i don't score nearly as well using MaxxMem Test as i was when my sticks were running at 2133Mhz the way they are supposed to. I have a mild overclock on CPU right now of 4.2Ghz without touching the voltage, it shows 0.906 V using CPU-Z and CPUID and shows up in bios reading 1.152 V.
  4. Did you increase the blck or just the multiplier while overclocking? If you increased the blck, reset that to default and increase the multiplier.
    1600MHz at 11-11-11-30 will be slow.
    What is the operating voltage of ram cards? Try increasing the voltage in small steps.
    I just did a test OC by raising multiplier to 42x, the specs on my ram are 1.65V but they default to 1.604V. I also tried lowering ram voltage to 1.5V but it just seems to revert back to 1.604V.
    The voltages shouldnot revert back by themselves also the default voltages should be 1.5volts and not 1.604volts. I think you should better go and get the motherboard replaced.
Motherboards ASrock
